problem with WMS TIME support and PostGIS
Bruno Canessa
b.canessa at IOL.IT
Thu Jan 18 07:06:40 EST 2007
Hi all,
I have a problem with WMS with TIME support and Postgis.
Inilially I created a map file where layers access direct to files, and
it works fine. I mean, the web service is able to process the TIME
parameter:
LAYER
NAME "Anomalie"
GROUP "Anomalie"
TYPE RASTER
STATUS ON
METADATA
"queryable" "true"
"tile_source" "nocache"
"wms_title" "Anomalie"
"wms_timeextent" "2006-05-01/2006-10-31"
"wms_timeitem" "datetime"
"wms_timedefault" "2006-05-10"
"wms_srs" "EPSG:4326"
END
TILEINDEX "epluie_a_idx.shp"
TILEITEM "Location"
CLASSITEM "[pixel]"
CLASS
END
END
On the contrary, if I try to access through Postgis it seems that the
TIME parameter is not recognised, it always shows the last image of the
index list.
LAYER
NAME "anomalie_idx"
STATUS ON
TYPE POLYGON
DATA "wkb_geometry from tileindex_table"
METADATA
"wms_title" "ANOMALIE INDEX"
"wms_timeitem" "datetime" #column in postgis table of type date
END
CONNECTION "dbname=test user=xxx host=localhost port=5432"
CONNECTIONTYPE postgis
END
LAYER
NAME "Anomalie"
GROUP "Anomalie"
TYPE RASTER
STATUS ON
DEBUG ON
PROJECTION
"init=epsg:4326"
END
METADATA
"queryable" "true"
END
TILEINDEX "anomalie_idx"
TILEITEM "Location"
CLASSITEM "[pixel]"
CLASS
END
END
I tried to perform queries in PostgreSQL such as
SELECT * FROM tileindex_table WHERE date_trunc('day', datetime) =
'2006-10-10';
and it works fine.
I use mapserver 4.8.4, PostgreSQL 8.1.4 and PostGIS 1.1.3
Any suggestion?
Thanks,
Bruno.
Dott. Bruno Canessa
National Research Council - Institute of Biometeorology (CNR-IBIMET)
Via G.Caproni, 8
50145 Firenze (Italy)
Tel. +39 055 3033719
Fax +39 055 308910
E-mail: b.canessa at iol.it <mailto:b.canessa at ibimet.cnr.it>
