problem with WMS TIME support and PostGIS
David William Bitner
david.bitner at GMAIL.COM
Thu Jan 18 10:51:52 EST 2007
Bruno --
You'll need to upgrade to MapServer 4.10 for PostGIS + WMST.
http://mapserver.gis.umn.edu/docs/howto/wms_time_support/#example-of-wms-t-with-postgis-tile-index-for-raster-imagery
David
On 1/18/07, Bruno Canessa <b.canessa at iol.it> wrote:
> Hi all,
> I have a problem with WMS with TIME support and Postgis.
> Inilially I created a map file where layers access direct to files, and
> it works fine. I mean, the web service is able to process the TIME
> parameter:
> LAYER
> NAME "Anomalie"
> GROUP "Anomalie"
> TYPE RASTER
> STATUS ON
> METADATA
> "queryable" "true"
> "tile_source" "nocache"
> "wms_title" "Anomalie"
> "wms_timeextent" "2006-05-01/2006-10-31"
> "wms_timeitem" "datetime"
> "wms_timedefault" "2006-05-10"
> "wms_srs" "EPSG:4326"
> END
> TILEINDEX "epluie_a_idx.shp"
> TILEITEM "Location"
> CLASSITEM "[pixel]"
> CLASS
> END
> END
> On the contrary, if I try to access through Postgis it seems that the
> TIME parameter is not recognised, it always shows the last image of the
> index list.
> LAYER
> NAME "anomalie_idx"
> STATUS ON
> TYPE POLYGON
> DATA "wkb_geometry from tileindex_table"
> METADATA
> "wms_title" "ANOMALIE INDEX"
> "wms_timeitem" "datetime" #column in postgis table of type date
> END
> CONNECTION "dbname=test user=xxx host=localhost port=5432"
> CONNECTIONTYPE postgis
> END
> LAYER
> NAME "Anomalie"
> GROUP "Anomalie"
> TYPE RASTER
> STATUS ON
> DEBUG ON
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "queryable" "true"
> END
> TILEINDEX "anomalie_idx"
> TILEITEM "Location"
> CLASSITEM "[pixel]"
> CLASS
> END
> END
> I tried to perform queries in PostgreSQL such as
> SELECT * FROM tileindex_table WHERE date_trunc('day', datetime) =
> '2006-10-10';
> and it works fine.
> I use mapserver 4.8.4, PostgreSQL 8.1.4 and PostGIS 1.1.3
> Any suggestion?
> Thanks,
> Bruno.
> Dott. Bruno Canessa
> National Research Council - Institute of Biometeorology (CNR-IBIMET)
> Via G.Caproni, 8
> 50145 Firenze (Italy)
> Tel. +39 055 3033719
> Fax +39 055 308910
> E-mail: b.canessa at iol.it <mailto:b.canessa at ibimet.cnr.it>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070118/27d30137/attachment.html
