NOT labelling certain features
Mike Saunt
mikesaunt at GMAIL.COM
Fri Jan 19 08:21:37 EST 2007
Thanks Stephen
For anyones reference the complete Layer Definition would now be:
LAYER
NAME MinorRoads
TYPE LINE
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "astun\MINORROADS.TAB"
MAXSCALE 60000
MINSCALE 10000
LABELMAXSCALE 50000
LABELITEM "DESCRIPTION"
TRANSPARENCY ALPHA # anti aliasing lines
CLASSITEM "DESCRIPTION"
CLASS
NAME "StreetLabels"
EXPRESSION /^(REAR OF|ACCESS)/
STYLE
COLOR 192 192 192
SYMBOL 'continue'
SIZE 5
ANTIALIAS TRUE
END
STYLE
COLOR 255 255 255
SYMBOL 'continue'
SIZE 3
ANTIALIAS TRUE
END
END
CLASS
NAME "StreetLabels"
STYLE
COLOR 192 192 192
SYMBOL 'continue'
SIZE 5
ANTIALIAS TRUE
END
STYLE
COLOR 255 255 255
SYMBOL 'continue'
SIZE 3
ANTIALIAS TRUE
END
LABEL
FONT "arial"
TYPE TRUETYPE
ANTIALIAS TRUE
COLOR 40 40 40
OUTLINECOLOR 255 255 255
SIZE 7
POSITION AUTO
PARTIALS FALSE
BUFFER 4
ANGLE AUTO
END
END
END
On 19/01/07, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> One more thing if you want to draw the objects but not label them then
> add the STYLE sections to the new CLASS but don't add the LABEL sections.
> -Steve W.
> Stephen Woodbridge wrote:
> > Mike,
> > Try adding the following to your mapfile. You may have to tweak the
> > regex a little.
> > -Steve W.
> > Mike Saunt wrote:
> >> Hi All
> >> I've got a layer of roads where the description of various roads
> >> starts "REAR OF" or "ACCESS TO". I want to be able to label all
> >> roads that DON'T start with these terms as these are insignificant
> >> roads to label. I'm a bit unsure of the Filter / Expression to
> >> achieve this.
> >> Any help appreciated!
> >> LAYER
> >> NAME MinorRoads
> >> TYPE LINE
> >> STATUS DEFAULT
> >> CONNECTIONTYPE OGR
> >> MAXSCALE 60000
> >> MINSCALE 10000
> >> LABELMAXSCALE 50000
> >> TRANSPARENCY ALPHA # so anti aliasing lines works
> > CLASS
> > NAME "Noop"
> > EXPRESSION /^(REAR OF|ACCESS TO)/
> > # catch them here and do nothing with them
> > END
> >> CLASS
> >> NAME "Streets"
> >> STYLE
> >> COLOR 192 192 192
> >> SYMBOL 'continue'
> >> SIZE 5
> >> ANTIALIAS TRUE
> >> END
> >> STYLE
> >> COLOR 255 255 255
> >> SYMBOL 'continue'
> >> SIZE 3
> >> ANTIALIAS TRUE
> >> END
> >> LABEL
> >> FONT "arial"
> >> TYPE TRUETYPE
> >> ANTIALIAS TRUE
> >> COLOR 40 40 40
> >> SIZE 7
> >> POSITION AUTO
> >> PARTIALS FALSE
> >> BUFFER 4
> >> ANGLE AUTO
> >> END
> >> END
> >> END
> >> Cheers
> >> Mike
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070119/9857917d/attachment.html
