USGS DEM in mapserver
Pietro Giannini
pgiannini at BYTEWISE.IT
Thu Jan 25 06:25:57 EST 2007
Thanks Zoltan!
I tried immediately and it work well ... but MS
does not reproject the raster!
The only way to display correctly the
raster is apply a lat/lon projection to the map, the same of the
raster.
In the same directory of the .dem is a world
file, with the same name of the Gtopo tile and extension ".wld",
I tried also to rename the world file to ".dmw", without
result.
I used .tif rasters, georeferenced with world files,
and MS reproject them without problem.
Another way to
georeference .dem rasters?
Anyone can help?
thanks, bye
.....................................pg
-------------------------- Messaggio originale
Oggetto: Re: [UMN_MAPSERVER-USERS] USGS
DEM in mapserver {Scanned}
Da: "Siki Zoltan"
<siki at AGT.BME.HU>
Data: Gio, 25 Gennaio 2007 2:52 pm
A:
MAPSERVER-USERS at LISTS.UMN.EDU
Hi Pietro,
I'm using Gtopo data. Simpli add a layer to
your map file.
AFAIK gdal can read it, it may depend on gdal
version.
My layer definition looks like:
LAYER
NAME
"e020n90"
DATA "e020n90.dem"
TYPE
RASTER
STATUS DEFAULT
CLASSITEM '[pixel]'
CLASS
NAME "Nodata"
EXPRESSION ([pixel] < 1)
COLOR 0 0 255
END
CLASS
NAME "0 - 50
m"
EXPRESSION ([pixel] >= 1 AND [pixel] < 50)
COLOR 0 119 32
END
END #of layer
Bye
Zoltan
On Thu, 25 Jan 2007, Pietro Giannini
wrote:
> Hi list,
> Is anyone
experienced about the USGS gTopo30 dataset
> and his use with
mapserver?
> This dataset contain a binary elevation
raster (.dem) in
> 16 bit signed integer.
Data is here:
(http://edc.usgs.gov/products/elevation/gtopo30/gtopo30.html)
> thank for any hint
> pg
Pietro Giannini
Bytewise srl - Area GIS
41°50'38.58"N 12°29'13.39"E
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070125/18b1fc16/attachment.html
