Does the current SDE driver in MapServer support logical and
regular expressio
Hong
ljfong at SDF.LONESTAR.ORG
Fri Jan 26 19:35:45 EST 2007
Then I guess I had the expression wrong then, here was the layer I had been
trying to display with multiple classifications:
LAYER # 9
NAME "Census Groups"
TYPE POLYGON
CONNECTION ...
CONNECTIONTYPE SDE
DATA "APACHE.APACHE.CENSUS_GROUP,SHAPE,SDE.DEFAULT"
STATUS ON
TRANSFORM ON
CLASSITEM "POP2000"
CLASS
EXPRESSION "[POP2000] >= 0 AND [POP2000] <= 400"
STYLE
COLOR 112 247 38
END
END
CLASS
EXPRESSION "[POP2000] >= 400 AND [POP2000] <= 800"
STYLE
COLOR 233 9 61
END
END
# Catch-all
CLASS
STYLE
COLOR 255 0 0
END
END
END
The CENSUS_GROUP table is an SDE table with SHAPE as its geometric field. The
field POP2000 is a numeric field of type 'int' with values from 21 to 3416.
MapServer ignored all other classifications and only rendered the layer by
"Catch-all" classification that rendered everything in red. No error or
warning from MapServer at all. Can someone show me the correct way of writing
the EXPRESSION in this case?
Thanks.
Hong
On Fri, Jan 26, 2007 at 05:08:31PM -0600, Steve Lime wrote:
> Expressions in classes are interpreted by MapServer not the underlying
> datasource for consistancy. So, the answer is yes.
> Steve
> >>> Hong <ljfong at SDF.LONESTAR.ORG> 1/26/2007 3:33:36 PM >>>
> The question is in the topic.
> Thanks.
> Hong
