configure crt1.o error on PPC64 RHEL
Daniel Morissette
dmorissette at MAPGEARS.COM
Wed Jan 31 09:14:05 EST 2007
Perhaps you could try running 'autoconf' in the mapserver source
directory to regenerate the configure script. This should not be
required, but perhaps the version of autoconf on your server will
include the required paths in its C compiler tests.
Daniel
Doug B wrote:
> The configure script is complaining that:
> checking for C compiler default output file name... configure: error:
> C compiler cannot create executables
> config.log says:
> /usr/bin/ld: crt1.o: No such file: No such file or directory
> collect2: ld returned 1 exit status
> configure:1704: $? = 1
> configure: failed program was:
> | /* confdefs.h. */
> | #define PACKAGE_NAME ""
> | #define PACKAGE_TARNAME ""
> | #define PACKAGE_VERSION ""
> | #define PACKAGE_STRING ""
> | #define PACKAGE_BUGREPORT ""
> | /* end confdefs.h. */
> | int
> | main ()
> | return 0;
> configure:1743: error: C compiler cannot create executables
> After a bit of searching, I see that glibc-devel is what provides this
> file, which I have now installed, but configure still gives the same
> error. The file exists under /usr/lib64.
> I get the same results with MapServer 4.10.0, 4.8.4, and 4.6.2. Line
> number above is from 4.8.4. This is on RHEL 2.6.9-42 for PPC64. I
> have no such problems on an old Fedora Core 2 system.
> Thanks for any assistance or advice.
> Doug
Daniel Morissette
http://www.mapgears.com/
