configure crt1.o error on PPC64 RHEL
Doug B
ummmmm22 at GMAIL.COM
Wed Jan 31 10:53:05 EST 2007
I did try that, but the output configure script had no differences at
all from the original one. Needless to say, it reported the same
error.
On 1/31/07, Daniel Morissette <dmorissette at mapgears.com> wrote:
> Perhaps you could try running 'autoconf' in the mapserver source
> directory to regenerate the configure script. This should not be
> required, but perhaps the version of autoconf on your server will
> include the required paths in its C compiler tests.
> Daniel
> Doug B wrote:
> > The configure script is complaining that:
> > checking for C compiler default output file name... configure: error:
> > C compiler cannot create executables
> > config.log says:
> > /usr/bin/ld: crt1.o: No such file: No such file or directory
> > collect2: ld returned 1 exit status
> > configure:1704: $? = 1
> > configure: failed program was:
> > | /* confdefs.h. */
> > | #define PACKAGE_NAME ""
> > | #define PACKAGE_TARNAME ""
> > | #define PACKAGE_VERSION ""
> > | #define PACKAGE_STRING ""
> > | #define PACKAGE_BUGREPORT ""
> > | /* end confdefs.h. */
> > | int
> > | main ()
> > | return 0;
> > configure:1743: error: C compiler cannot create executables
> > After a bit of searching, I see that glibc-devel is what provides this
> > file, which I have now installed, but configure still gives the same
> > error. The file exists under /usr/lib64.
> > I get the same results with MapServer 4.10.0, 4.8.4, and 4.6.2. Line
> > number above is from 4.8.4. This is on RHEL 2.6.9-42 for PPC64. I
> > have no such problems on an old Fedora Core 2 system.
> > Thanks for any assistance or advice.
> > Doug
> Daniel Morissette
> http://www.mapgears.com/
