Strange mapscriptJNI_delete_1layerObj+0xf error killing Tomcat
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Fri Jun 1 03:10:22 EDT 2007
I suggest against this practice (no pun intended Benedikt, I sincerely
appreciate your help).
I say let's wait until Rodrigo tries out a rfc-24 enabled build,
frankly I am quite positive rfc-24 will fix his issues.
Regards,
Umberto
On 6/1/07, Benedikt Rothe <umn-ms at hydrotec.de> wrote:
> Hi
> Some developers (Umberto, Tamas) work on a solution of this problem.
> As a workaround I made good experiences with
> http://lists.umn.edu/cgi-bin/wa?A2=ind0506&L=mapserver-users&P=87500
> > if we dynamically create mapserver-objects, we allway use code like this:
> > classObj cO = new classObj(...);
> > // Do something with cO
> > //now cO isn't used any more
> > cO.delete()
> With "freeing manually" we made the Mapserver inside Tomcat quite stable.
> Hope, this helps
> Benedikt
> UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
> 31.05.2007 15:13:41:
> > Hello dear list.
> > A problem is happening in our production machine which we were
> > unable to reproduce on our development machines. We have a very
> > large application almost ready for deployment, in which one of the
> > modules is written in java mapscript 4.10.1, and the error on the
> > attached log happened for the first time when we installed the
> > application on the production server. Whats worse, the GIS module
> > causing the error brings down Tomcat and the whole application with it.
> > This is a excerpt from the JVM log:
> > # An unexpected error has been detected by HotSpot Virtual Machine:
> > # SIGSEGV (0xb) at pc=0x636ff93b, pid=19162, tid=1759710128
> > # Java VM: Java HotSpot(TM) Server VM (1.5.0_07-b03 mixed mode)
> > # Problematic frame:
> > # C [libmapscript.so+0x3893b]
> Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1layerObj+0xf
