Strange mapscriptJNI_delete_1layerObj+0xf error killing Tomcat
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Fri Jun 1 11:38:45 EDT 2007
On 6/1/07, Oliver Wesp <wesp at gdv.com> wrote:
> Hi everybody,
> I just want thank everybody for the information in this thread. We're
> facing similar issues with java mapscript crashing the vm. Unfortunately
> the application relies on the dynamic creation of layers and classes.
> I tried the svn version this afternoon and it seems to be stable. No
> more tomcat crashes till now. I will do some more testing on monday but
> it looks like Umberto was right with expecting some good news :-)
Yes, party time! ;-)
Umberto
> Just in case this information is usefull: We're running our application
> on Solaris 8 using Shapefiles, GDAL Raster (HFA) and WMS as datasources.
> Tomcat is 5.0.28, JAVA is j2sdk1.4.2_11.
> Regards,
> Oliver
> Umberto Nicoletti schrieb:
> > I suggest against this practice (no pun intended Benedikt, I sincerely
> > appreciate your help).
> > I say let's wait until Rodrigo tries out a rfc-24 enabled build,
> > frankly I am quite positive rfc-24 will fix his issues.
> > Regards,
> > Umberto
> > On 6/1/07, Benedikt Rothe <umn-ms at hydrotec.de> wrote:
> >> Hi
> >> Some developers (Umberto, Tamas) work on a solution of this problem.
> >> As a workaround I made good experiences with
> >> http://lists.umn.edu/cgi-bin/wa?A2=ind0506&L=mapserver-users&P=87500
> >> > if we dynamically create mapserver-objects, we allway use code like
> >> this:
> >> > classObj cO = new classObj(...);
> >> > // Do something with cO
> >> > //now cO isn't used any more
> >> > cO.delete()
> >> With "freeing manually" we made the Mapserver inside Tomcat quite stable.
> >> Hope, this helps
> >> Benedikt
> >> UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
> >> 31.05.2007 15:13:41:
> >> > Hello dear list.
> >> > A problem is happening in our production machine which we were
> >> > unable to reproduce on our development machines. We have a very
> >> > large application almost ready for deployment, in which one of the
> >> > modules is written in java mapscript 4.10.1, and the error on the
> >> > attached log happened for the first time when we installed the
> >> > application on the production server. Whats worse, the GIS module
> >> > causing the error brings down Tomcat and the whole application with
> >> it.
> >> > This is a excerpt from the JVM log:
> >> > # An unexpected error has been detected by HotSpot Virtual Machine:
> >> > # SIGSEGV (0xb) at pc=0x636ff93b, pid=19162, tid=1759710128
> >> > # Java VM: Java HotSpot(TM) Server VM (1.5.0_07-b03 mixed mode)
> >> > # Problematic frame:
> >> > # C [libmapscript.so+0x3893b]
> >> Java_edu_umn_gis_mapscript_mapscriptJNI_delete_1layerObj+0xf
> Dipl.-Geogr. Oliver Wesp
> GDV Gesellschaft für geografische Datenverarbeitung mbH
> Binger Str. 49-51
> 55218 Ingelheim am Rhein
> Germany
> Fon 049(0)6132-7148-18
> Fax 049(0)6132-7148-28
> www.gdv.com
> Sitz der Gesellschaft: Ingelheim
> Amtsgericht Mainz HRB 23123
> Gerichtsstand Mainz
> Geschäftsführer: Thomas Riehl, Dirk Hübener
