Error compiling from SVN rev 6166
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Sat Jun 2 05:21:33 EDT 2007
On 6/2/07, Tamas Szekeres <szekerest at gmail.com> wrote:
> I think it's a java specific issue. The C# tests using this sample map
> are running pretty well, see:
> http://buildbot.osgeo.org:8504/
> Maybe Umberto will have some further idea in this topic.
Yes I have, and we all can have it since it's in svn revision 6167 and
tracked by bug #2108.
It was actually a quite serious issue. We need SteveL to have a look at this.
Umberto
> Best regards,
> Tamas
> 2007/6/1, Rodrigo Del C. Andrade <rodrigo.andrade at digitro.com.br>:
> > Nope =(
> > My distro had the old 2.5.4a, but I updated it to 2.5.33 and
> > recompiled both mapserver and mapscript but it had no effect, same
> > error. Is it documented somewhere changes (migration guide) for this
> > future released?
> > I might be missing something obvious :\
> > Thanks,
> > Rodrigo
> > Tamas Szekeres wrote:
> > > This version requires a newer version of the lexer, apparently flex
> > > 2.5.31 or so.
> > > This issue might be related to this change.
> > > Best regards,
> > > Tamas
> > >> Hi folks.
> > >> Following the previous discussion about rfc-24, I am trying to
> > >> compile a version from Svn latest revision (6166). All is fine and dandy
> > >> till I try to test the java mapscript lib created.
> > >> Going trough the usual configure and make, mapserver shows no
> > >> problems, same with mapscript/java with make interface and make: no
> > >> problems.
> > >> But 'make test' outputs
> > >> java -classpath ./:examples/:./mapscript.jar -Djava.library.path=.
> > >> WxSTest ../../tests/test.map
> > >> Exception in thread "Thread-2" java.lang.UnknownError: loadLayer():
> > >> Unknown identifier. Parsing error near (MAP):(line 1)
> > >> at edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
> > >> at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:280)
> > >> at WxSTest_thread.run(WxSTest.java:11)
> > >> Document Length: 9658, expecting somewhere around 10000 or more.
> > >> I am using the same libraries (gd, proj, etc) I had compiled for
> > >> 4.10.1 and other than that the enviroment is the same. I also tried
> > >> issuing a dos2unix to the offending test.map thinking it could be a
> > >> windows carriage return format file, but its not. Swig is version
> > >> 1.3.29, btw.
> > >> Regards,
> > >> Rodrigo
