Error compiling from SVN rev 6166
Tamas Szekeres
szekerest at GMAIL.COM
Fri Jun 1 18:30:23 EDT 2007
I think it's a java specific issue. The C# tests using this sample map
are running pretty well, see:
http://buildbot.osgeo.org:8504/
Maybe Umberto will have some further idea in this topic.
Best regards,
Tamas
2007/6/1, Rodrigo Del C. Andrade <rodrigo.andrade at digitro.com.br>:
> Nope =(
> My distro had the old 2.5.4a, but I updated it to 2.5.33 and
> recompiled both mapserver and mapscript but it had no effect, same
> error. Is it documented somewhere changes (migration guide) for this
> future released?
> I might be missing something obvious :\
> Thanks,
> Rodrigo
> Tamas Szekeres wrote:
> > This version requires a newer version of the lexer, apparently flex
> > 2.5.31 or so.
> > This issue might be related to this change.
> > Best regards,
> > Tamas
> >> Hi folks.
> >> Following the previous discussion about rfc-24, I am trying to
> >> compile a version from Svn latest revision (6166). All is fine and dandy
> >> till I try to test the java mapscript lib created.
> >> Going trough the usual configure and make, mapserver shows no
> >> problems, same with mapscript/java with make interface and make: no
> >> problems.
> >> But 'make test' outputs
> >> java -classpath ./:examples/:./mapscript.jar -Djava.library.path=.
> >> WxSTest ../../tests/test.map
> >> Exception in thread "Thread-2" java.lang.UnknownError: loadLayer():
> >> Unknown identifier. Parsing error near (MAP):(line 1)
> >> at edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
> >> at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:280)
> >> at WxSTest_thread.run(WxSTest.java:11)
> >> Document Length: 9658, expecting somewhere around 10000 or more.
> >> I am using the same libraries (gd, proj, etc) I had compiled for
> >> 4.10.1 and other than that the enviroment is the same. I also tried
> >> issuing a dos2unix to the offending test.map thinking it could be a
> >> windows carriage return format file, but its not. Swig is version
> >> 1.3.29, btw.
> >> Regards,
> >> Rodrigo
