updating Proj's epsg list
anthony farrant
anthony.k.farrant at GMAIL.COM
Mon Jun 4 03:49:37 EDT 2007
It's a projection that came with the demo's of Chameleon. It's a
Canada projection and it's written in epsg:form. I don't think it's an
esri projection but I'll give your suggestion a try later on.
The funny thing is that it's in the epsg file of ms4w but not in that
of mapserver for linux that I compiled on debian.
-A
> Where did the epsg number 42304 come from? It is from an ESRI project?
> If so you might try using esri:42304 instead of epsg:42304
> epsg is an organization the publishes standard projections code and
> definitions. esri also has their own set of codes and definitions. There
> are separate files for these to lists specifically epsg and ersi.
> -Steve W.
