MapScript projection error - CGI works fine
Pascal Ehlert
dadark at DADARK.DE
Tue Jun 12 15:10:13 EDT 2007
Hi Frank!
I figured that out myself in the meantime, I used the mapserver from the
debian package
and compiled mapscript on my own.
As Ruby mapscript isn't very well documented and I didn't check the
whole sourcecode yet,
does anyone know how up-to-date it is?
Are at least the current main features supported?
Thank you (especially Frank for your help of course)
Pascal
Frank Warmerdam schrieb:
> Pascal Ehlert wrote:
>> Hi Mapserver Community!
>> This is my first post here, I hope the project is still active.
>> I've just been trying to migrate my MapServer stuff from the CGI
>> version to
>> the Ruby MapScript version
>> for better integration with my Rails (for those of you who don't
>> know, it's
>> a Ruby web framework) application.
>> Now, while CGI is working fine, the MapScript refuses to work at all,
>> because of a projection error.
>> This really confuses me, I'm using exactly the same mapfile for both
>> of them.
>> This is what I do in Ruby and the error I get:
> > RuntimeError: loadProjection(): Projection library error. Projection
> support
> > is not available.
> Pascal,
> This generally means that your Ruby mapscript was built without PROJ.4
> support. I think you need to rebuild ruby mapscript ensuring that PROJ.4
> support is enabled during the full build of mapscript and the underlying
> mapserver library. I'm guessing that your mapscript and mapserver cgi
> are
> not from the same build.
> PS. MapServer is still very active, though perhaps Ruby Mapscript is only
> lightly used.
> Best regards,
