Small differences in input and output
Ed McNierney
ed at TOPOZONE.COM
Thu Jun 14 11:11:13 EDT 2007
Frank -
Yes, thanks very much - that's what I meant (the EXTENT is 990 in each
direction), not what I typed <g>.
- Ed
Ed McNierney
President and Chief Mapmaker
Maps a la carte, Inc. / TopoZone.com
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: (978) 251-4242
Fax: (978) 251-1396
ed at topozone.com
> From: Frank Warmerdam <warmerdam at POBOX.COM>
> Reply-To: Frank Warmerdam <warmerdam at POBOX.COM>
> Date: Thu, 14 Jun 2007 11:07:03 -0400
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Subject: Re: [UMN_MAPSERVER-USERS] Small differences in input and output
> Ed McNierney wrote:
>> Frank -
>> For MapServer EXTENT purposes Benoit will need to adjust the extents by one
>> whole pixel rather than by half a pixel? If there are N pixels horizontally
>> measured from the center of the left-hand to the center of the right-hand
>> pixel, then there are N+1 pixels measured from the left of the left-hand to
>> the right of the right-hand pixel, rather than N+0.5.
>> That is, if you adjust all four corners "in" by 0.5 pixel you'll reduce the
>> height and width by 1 whole pixel each.
> Ed,
> If the original file is 100 x 100 (for instance) with gdal reported extents
> of (0,0) to (1000,1000) then the mapfile should contain:
> EXTENT 5 5 995 995
> SIZE 100 100
> So the size is determined by the SIZE keyword - not the extents.
> Note that mapserver macros like MS_CELLSIZE already account for the fact
> that the extents represent a region that is in a sense n-1 pixels wide/long.
> eg.
> #define MS_CELLSIZE(min,max,d) ((max - min)/(d-1))
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
