WMS, time support, and Oracle
John Cartwright
John.C.Cartwright at NOAA.GOV
Thu Jun 14 11:43:09 EDT 2007
Thanks for your reply, David. I can get the same data to work fine in
postgres, but when using oracle I see the error:
msDrawMap(): Image handling error. Failed to draw layer named
'Hurricanes'.
msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error:
ORA-01861: literal does not match format string
. Query statement: SELECT OBJECTID, SHAPE FROM HYDRO.HURRICANES_TSQP
WHERE (hurr_date >= '2004-01-01' AND hurr_date <=
'2004-12-31') AND SDO_FILTER( SHAPE, MDSYS.SDO_GEOMETRY(2003,
8307,
NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-180,-90,180,90)
),'querytype=window') = 'TRUE' . Check your data statement.
Seems to be an oracle-specific time formatting problem.
-- john
David William Bitner wrote:
> John --
> I have not used WMS-T with Oracle, but have you seen the docs for
> using WMS-T with postgis?
> http://mapserver.gis.umn.edu/docs/howto/wms_time_support/#example-of-wms-t-with-postgis-tile-index-for-raster-imagery
> David
> On 5/29/07, *John Cartwright * <John.C.Cartwright at noaa.gov
> <mailto:John.C.Cartwright at noaa.gov>> wrote:
> Hello All,
> I've having trouble getting the time requests passed to Oracle in
> a way
> that it understands. Has anyone done this successfully?
> Thanks!
> -- john
