postgis
Ernesto Vega
ernesvega at GMAIL.COM
Thu Jun 14 12:04:34 EDT 2007
Giuseppe :
I´ve never been into the situation of having 2 points overlapped.
For a better idea is useful to send which versions of postgresql and
postgis your are using.
For the class question:
Are you planning to dynamically change your parameter ?
If so, you must read the chapter dedicated on how to use parameters on
mapserver site, otherwise you may have no choice because of what you
want to alter within a class
hope this helps.
Ernesto Vega
On 6/14/07, Giuseppe Molinario <g.molinario at gmail.com> wrote:
> Hi everyone,
> I am working with a postgis point table that needs to be displayed in a
> mapserver application (pmapper).
> my problems:
> 1. what happens when two points are in the same exact location? ( the rows
> in my table can sometimes have the identical lat long coordinates and
> therefore geometry column.)
> how can i set the mapfile to show me both points and labels? is this ever
> possible? I realize this is a bit of werid question, but i am not asking
> about topology...just nuts and bolt postgis/mapfile....
> the query tool does not respond anymore. seems like having two identical
> points prevents the query tool from working
> this all worked prior to me having "overlapping" points2. different
> question. Layer>class in mapfile: I have an EXPRESSION object that goes like
> this EXPRESSION ([ID_specie_att]=2) now how do i get the SAME class to
> display both points that have value 2,3,4,5,6? Do i really have to make 5
> different classes? I would rather not because i don't want them in my
> legend.
> thanks very much for any help.
> Giuseppe
