ogrtindex labeling
Travis Kirstine
traviskirstine at GMAIL.COM
Thu Jun 14 12:15:15 EDT 2007
Hi All,
I have a several shapefiles all with identical schemas which I created
a tile index for using ogrtindex.
>ogrtindex index.shp /var/www/data/*.shp
I then in my mapfile connect to the tile index in my mapfile using ogr
CONNECTIONTYPE OGR
TILENDEX "/var/www/data/index.shp,0"
I then try to label the feature based on a field in the attribute tables
LABELITEM "NAME"
When I run shp2img I get the following error:
msOGRLayerInitItemInfo(): OGR error. Invalid Field name: NAME
Is there something I'm missing or does the ogr connection with a
tileindex not support labeling or querying by attributes.
Travis K.
Toronto, Canada
"She knows there's no success like failure
And that failure's no success at all."
-Bob Dylan-
