can layers be linked?
Guillaume Sueur
guillaume.sueur at GEOSIGNAL.FR
Mon Jun 18 03:54:05 EDT 2007
Hi Nelson,
You can use the GROUP attribute for each layer, setting it to the same
value (ex : GROUP "COMPOSITE")
they'll not be linked, but you'll be able to retrieve thse layers using
the group name :
$aLayers = $pMap->getLayersIndexByGroup("COMPOSITE")
and then loop on the $aLayers array to switch then on/off
Regards,
Guillaume SUEUR
LITTLE Nelson a écrit :
> Hi,
> I would like to link two layers of different geometry types. 1 layer
> contains points, the other layer contains lines. The points and lines
> are shown together to display a composite object on a map. If the user
> no longer wants to see that composite object on the map then I would
> like to turn off both of the layers. I am sure I can do it
> programmatically, but I would like to know if they can be linked in the
> MapFile?
> Thanks,
> Nelson
Guillaume SUEUR
