php/mapscript Unable to load dynamic library php_mapscript.so
=?GB2312?Q?feigle_Dou?=
feigle at 126.COM
Tue Jun 19 09:05:54 EDT 2007
Hi=A3=ACAll ,
I am trying to install php as a php/mpscript of mapserver . but when I t=
est=20
it , there is a warning :
=A1=B0Warning: dl() [function.dl]: Unable to load dynamic=20
library '/usr/local/php5/lib/php/extensions/no-debug-non-zts-
20060613/php_mapscript.so' - /usr/local/php5/lib/php/extensions/no-debug-=
non-zts-20060613/php_mapscript.so: cannot open shared object file: No suc=
h=20
file or directory in /var/www/html/mytest.php on line 3=A1=B1
The following is what I have done:
1=09My OS is Fedora Core 5 i386 , It has php preinstalled so I uninstall =
it=20
Rpm =A8Cq php =A8Cnodeps
2=09Install all the libraries in /usr/local/, such as gdal proj =A1=AD
3=09Install php in /usr/local/php5 . The version of php is php-5.2.2
./configure =A8Cenable-share=20=20
--with-regex=3Dsystem=20=20
--with-gd=3D/usr/local=20=20
--enable-force-cgi-redirect
--enable-dbase
--with-config-file-path=3D/usr/local/php5
--prefix=3D/usr/local/php5
Make=20
Meke test
Make install
Cp sapi/cgi/php /var/www/cgi-bin/php
Cp php.ini-dist /usr/local/lib/php.ini
Vi php.ini
# Add two line :
extension_dit=3D=A1=B1/usr/local/php5/lib/php/extensions=A1=B1
extension =3D =A1=B0php_mapscript.so=A1=B1
4 configure and install mapserver
./configure =A8Cwith-org=3D/usr/local/bin/gdal-config
--with-gdal=3D/usr/local/bin/gdal-config
--with-httpd=3D/usr/sbin/httpd
--with-proj=3D/usr/local
--with-freetype=3D/usr/
--with-php=3D/usr/local/php5
Make
=20=20
Cp ./mapscript/php3/php_mapscrpt.so /usr/local/php5/lib/php/extension=
s/
/sbin/ldconfig =A8Cv
/sbin/ldconfig /usr/local =A8Cv
Then I run ./mapserv
It works well
Cp mapserv /var/www/cgi-bin/
# Vi httpd.conf
# Add lines as followed
AddTpye application/x-httpd-php .phtml
Action php-sctipt /cgi-bin/php
AddHandler php-script .php
But when vi a file mytest.php in DormentRoot=20
<?php
dl(=A1=B0php_mapscript.so=A1=B1);
phpinfor();
It will show the warning message .
Can you give me some idea?
Any help will be appreciated,
Thanks a million!!
Best wishes,
feigle
