Problem with compilation sde support
Martin Koska
martin.koska at SAZP.SK
Wed Jun 20 04:35:17 EDT 2007
We have problem with compilation of sde 9.1 support for mapserver 4.10 in
Debian Linux operation system:
Sde 9.1 is installed in /opt/sde/sdeexe91.
We have following files in lib directory:
developer sdeexe91 # ls lib/
dbtune_util.spb libicuuc.so.22.0 locator_util.sps sdo_util.spb
dbtune_util.sps libloceng.so lock_util.spb sdo_util.sps
layers_util.spb liblocssa.so lock_util.sps sref_util.spb
layers_util.sps libmtchloc.so logfile_util.spb sref_util.sps
libedgemt.so libmtchmt.so logfile_util.sps
svr_config_util.spb
libgsrvrora9i91.so libpe91.so metadata_util.spb
svr_config_util.sps
libicudata.so libsde91.so metadata_util.sps
version_user_ddl.spb
libicudata.so.22 libsdeora9isrvr91.so pinfo_util.spb
version_user_ddl.sps
libicudata.so.22.0 libsg91.so pinfo_util.sps
version_util.no_state_seq.spb
libicui18n.so libtiff.so rastercolumns_util.spb
version_util.spb
libicui18n.so.22 libxerces-c.so rastercolumns_util.sps
version_util.sps
libicui18n.so.22.0 libxerces-c.so.21 registry_util.spb xml_util.spb
libicuuc.so libxerces-c.so.21.0 registry_util.sps xml_util.sps
libicuuc.so.22 locator_util.spb sde_util.sps
Configuration command is:
./configure --prefix=/usr --enable-debug --without-tiff --without-pdf
--with-gd=/usr --with-freetype=/usr --with-zlib=/usr --with-png=/usr
--with-xpm=/usr --with-jpeg=/usr --with-gdal --with-ogr --with-proj
--with-eppl --with-postgis --with-wcs --with-wms --with-wmsclient --with-wfs
--with-wfsclient --with-threads --with-geos --with-sde-version=91
--with-sde=/opt/sde/sdeexe91
Error:
configure: checking whether we should include ESRI SDE support...
configure: error: "Could not find sdetype.h or libsde91.a/libsde91.so in
/opt/sde/sdeexe91."
File libsde91.so is located in /opt/sde/sdeexe91/lib
Can anybody help to solve the problem?
What's wrong with this?
Thank you.
Martin Koska
martin.koska at sazp.sk
