Problem with compilation sde support
Tim Bowden
tim.bowden at WESTNET.COM.AU
Wed Jun 20 04:57:48 EDT 2007
On Wed, 2007-06-20 at 03:35 -0500, Martin Koska wrote:
> We have problem with compilation of sde 9.1 support for mapserver 4.10 in
> Debian Linux operation system:
> Sde 9.1 is installed in /opt/sde/sdeexe91.
<snip>
> Configuration command is:
> ./configure --prefix=/usr --enable-debug --without-tiff --without-pdf
> --with-gd=/usr --with-freetype=/usr --with-zlib=/usr --with-png=/usr
> --with-xpm=/usr --with-jpeg=/usr --with-gdal --with-ogr --with-proj
> --with-eppl --with-postgis --with-wcs --with-wms --with-wmsclient --with-wfs
> --with-wfsclient --with-threads --with-geos --with-sde-version=91
> --with-sde=/opt/sde/sdeexe91
> Error:
> configure: checking whether we should include ESRI SDE support...
> configure: error: "Could not find sdetype.h or libsde91.a/libsde91.so in
> /opt/sde/sdeexe91."
> File libsde91.so is located in /opt/sde/sdeexe91/lib
> Can anybody help to solve the problem?
> What's wrong with this?
Try putting /opt/sde/sdeexe91/lib in /etc/ld.so.conf and running
ldconfig.
> Thank you.
> Martin Koska
> martin.koska at sazp.sk
HTH,
Tim Bowden
