How to use queryByShape
Nico Alberti
nico at LANGHIRANO.IT
Wed Jun 20 10:35:08 EDT 2007
Hi everybody. I am quite new to php_mapscript, so excuse me if the
question is lame.
I am trying to select which points of a shape are inside a particular
area, (a shape from a polygon shapefile), so I do something like
this, after having instantiated the objects:
$map->prepareQuery();
$ret=$layerPoints->queryByShape($ShapeAreaObject);
However, even if I am sure that some points fall within the area of
$ShapeAreaObject, nothing is selected. It seems I am missing
something, but after having read the documentation and the list, I did
not find any clue. Using the php_ogr extension, the points that fall
within the area (or better its envelope) are correctly selected, but,
again, it is certainly my fault, as it's the first time I use this
library.
Any help will be greatly appreciated, thank you in afvance
Ciao
Nico
