working with database in UTF-8
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Fri Jun 22 13:52:27 EDT 2007
Hmmm... All the encoding parameter does is tell MapServer to convert from the supplied encoding to
unicode so I don't think it has any effect. If you already have unicode/utf-8 strings then this should
just work assuming your font has the right characters.
Does a simple shapefile work?
Steve
>>> On 6/22/2007 at 2:56 AM, in message
<bfb704a40706220056t20220029n82b4ec43aa5e3854 at mail.gmail.com>, Jackey Cheung
<cheung.jackey at GMAIL.COM> wrote:
> Greetings!
> I'm trying to setup a mapserver that supports multiple languages with MySQL.
> The database uses UTF-8, while the map server use a select statement to
> retrieve records. The layer goes as:
> LAYER
> NAME sr
> STATUS OFF
> TYPE POINT
> CONNECTIONTYPE OGR
> CONNECTION "<OGRVRTDataSource>
> <OGRVRTLayer name='sr'>
> <SrcDataSource>MYSQL:MapSQL,user=root,password=123456,host=localhost,port=3306
> ,tables=POI</SrcDataSource>
> <SrcSQL>SELECT `Name`, geom
> FROM `POI` WHERE `ID` = %o%</SrcSQL>
> <GeometryType>wkbPoint</GeometryType>
> </OGRVRTLayer>
> </OGRVRTDataSource>"
> DATA "sr"
> UNITS METERS
> MAXFEATURES 1
> LABELITEM "Name"
> CLASS
> SYMBOL "point"
> MINSIZE 10
> COLOR 250 0 0
> OUTLINECOLOR 0 128 0
> LABEL
> ENCODING "utf-8"
> COLOR 255 0 0
> OUTLINECOLOR 255 255 255
> TYPE TRUETYPE
> FONT arial
> SIZE 8
> ANTIALIAS TRUE
> POSITION UC
> PARTIALS FALSE
> BUFFER 5
> FORCE TRUE
> END
> END
> END
> All Chinese characters are shown as question marks (?) on the map, no mater
> using arial or Chinese fonts.
> Any advise?
