working with database in UTF-8
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Jun 22 14:45:46 EDT 2007
Jackey,
I suspect that the font file is not utf8 or the data is already mangled
before it gets to mapserver. The mapserver stuff works fine for me with
utf-8 data in shapefiles as long as I set the ENCODING 'utf8' in the
LABEL. A bigger issue might be:
What is the encoding on the source data?
what is the encoding on the database?
was the data loded correct with respect to the encoding?
if you do a select * from table in mysql does the data display correctly?
if you slect the records with ogrinfo? to a file or you monitor do they
show corectly?
There are a WHOLE lot oof steps where things could have broken before it
gets to mapserver. You need to validate the data is still good as it
comes into mapserver.
-Steve W.
Steve Lime wrote:
> Hmmm... All the encoding parameter does is tell MapServer to convert from the supplied encoding to
> unicode so I don't think it has any effect. If you already have unicode/utf-8 strings then this should
> just work assuming your font has the right characters.
> Does a simple shapefile work?
> Steve
>>>> On 6/22/2007 at 2:56 AM, in message
> <bfb704a40706220056t20220029n82b4ec43aa5e3854 at mail.gmail.com>, Jackey Cheung
> <cheung.jackey at GMAIL.COM> wrote:
>> Greetings!
>> I'm trying to setup a mapserver that supports multiple languages with MySQL.
>> The database uses UTF-8, while the map server use a select statement to
>> retrieve records. The layer goes as:
>> LAYER
>> NAME sr
>> STATUS OFF
>> TYPE POINT
>> CONNECTIONTYPE OGR
>> CONNECTION "<OGRVRTDataSource>
>> <OGRVRTLayer name='sr'>
>> <SrcDataSource>MYSQL:MapSQL,user=root,password=123456,host=localhost,port=3306
>> ,tables=POI</SrcDataSource>
>> <SrcSQL>SELECT `Name`, geom
>> FROM `POI` WHERE `ID` = %o%</SrcSQL>
>> <GeometryType>wkbPoint</GeometryType>
>> </OGRVRTLayer>
>> </OGRVRTDataSource>"
>> DATA "sr"
>> UNITS METERS
>> MAXFEATURES 1
>> LABELITEM "Name"
>> CLASS
>> SYMBOL "point"
>> MINSIZE 10
>> COLOR 250 0 0
>> OUTLINECOLOR 0 128 0
>> LABEL
>> ENCODING "utf-8"
>> COLOR 255 0 0
>> OUTLINECOLOR 255 255 255
>> TYPE TRUETYPE
>> FONT arial
>> SIZE 8
>> ANTIALIAS TRUE
>> POSITION UC
>> PARTIALS FALSE
>> BUFFER 5
>> FORCE TRUE
>> END
>> END
>> END
>> All Chinese characters are shown as question marks (?) on the map, no mater
>> using arial or Chinese fonts.
>> Any advise?
