working with database in UTF-8
Jackey Cheung
cheung.jackey at GMAIL.COM
Tue Jun 26 23:22:19 EDT 2007
hmm, yes, you've reminded me 'bout the box and question marks. thx.
Currently, all data in the mysql database use utf8, and I'm running a wfs
server with the same data, which seems fine. I can use openlayers running in
ie or firefox to retrieve data and show them correctly on screen, using utf8
encoding. Question marks show up only in mapserver generated images.
Any advise how can I pin down the cause of this problem?
----- Original Message -----
To: "Jackey Cheung" <cheung.jackey at GMAIL.COM>
Cc: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Wednesday, June 27, 2007 10:09
Subject: Re: [UMN_MAPSERVER-USERS] working with database in UTF-8
> Jackey Cheung wrote:
>> Well, it shows a bunch of question marks (?) no matter I use arial or
>> big5 fonts. I don't know how to check out the encoding of fonts, and I
>> don't know which font to use for the case.
> ? indicate that your data is garbaged somewhere along the line, usually
> from a serious encoding mismatch. mojibake (@$%!?<+~ etc.) usually means
> simple encoding mismatch. if you see boxes instead of chars, that's a font
> issue.
