beginner: text region polyline point from MapInfo
Julien Buratto
mapserver at LINKAS.IT
Mon Mar 5 06:00:32 EST 2007
Great, it works! thanks a lot!
Julien
Siki Zoltan ha scritto:
> Hi Julien,
> ESRI shapes are only for points, lines and polygons (regions).
> Universal translator converts MapInfo texts to line elements and the
> text string to an attribute. So you can display them as an annotation type
> layer.
> So change your layer something like this
> LAYER
> DEBUG OFF
> NAME "text"
> TYPE ANNOTATION
> STATUS OFF
> TILEINDEX "priamo_text.shp"
> TILEITEM "location"
> LABELITEM "TEXTSTRING"
> CLASS
> NAME "region"
> LABEL
> SIZE ?
> TYPE TRUETYPE
> FONT ???
> COLOR ? ? ?
> ANGLE "TEXT_ANGLE"
> END
> END
> END
> You must use truetype font to rotate text.
> Zoltan
> On Fri, 2 Mar 2007, Julien Buratto wrote:
>> Rahkonen Jukka ha scritto:
>>> Hi,
>>> Correct. While MapInfo tab is database-like format and can contain everything you may have in MapInfo in a single file, ESRI shapefiles can only have one kind of features in one shapefile set.
>>> -Jukka-
>> Great, so I'm getting it :-D
>> Next question is, what "type" should I use to draw texts ?
>> My layer containing text is:
>> LAYER
>> DEBUG OFF
>> NAME "text"
>> TYPE point
>> STATUS OFF
>> TILEITEM "location"
>> CLASS
>> NAME "region"
>> STYLE
>> # OUTLINECOLOR 120 120 120
>> COLOR 0 0 0
>> END
>> END
>> END # layer
>> the MAP header is:
>> MAP
>> NAME DEMO
>> IMAGECOLOR 255 255 255
>> SIZE 530 530
>> Extent 2285117.310158 4727319.440000 2431485.920000 4871301.690000
>> FONTSET ../etc/fonts.txt
>> Thanks again
