Mapinfo Seamless Vector tables in mapserver
mikiet
mike.talbutt at DOTTEDEYES.COM
Tue Mar 6 11:39:59 EST 2007
Ah some success.
I've managed to get this to work by
1. Moving all by base tables into the same directory
2. Creating my seamless layer with the 'no path' option set.
I can now access the data using ogrinfo regardless of whether or not I
include the path to the tab file, and the data displays in my mapserver
application.
Frank Warmerdam-2 wrote:
> mikiet wrote:
>> No dice eh ?, I have alittle more information in case it sheds some light
>> on
>> whats going on.
>> I have set up the seamless table using mapinfo pro's seamless manager
>> tool,
>> specifying full path. I noticed that if I do an ogrinfo on my table it
>> works
>> fine
>> C:\Tomcat5\webapps\rmxnyf\mapbase>ogrinfo test.tab
>> Had to open data source read-only.
>> INFO: Open of `test.tab'
>> using driver `MapInfo File' successful.
>> 1: Area_Mosaic (Line String)
> Miki,
> Try doing "ogrinfo -al -so C:\Tomcat5\webapps\rmxnyf\mapbase\test.tab"
> from some different directory to see if the case similar to the
> absolute path in mapserver works with ogrinfo.
>> However when i specify the full path of the tab file I get an error
>> .TAB
>> FAILURE:
>> Unable to open datasource `C:\Tomcat5\webapps\rmxnyf\mapbase\test.TAB'
>> with
>> the
>> following drivers.
>> -> OCI
>> -> ESRI Shapefile
>> -> MapInfo File
>> When I do this test on a normal (non seamless) tab file ogrinfo works
>> fine
>> regardless of whether or not I specify the full name.
>> Is this a clue as to where it's all going wrong ?.
> I suspect path or permissions problems. Internally the OGR needs to
> construct paths to the component files of the seamless layer, and
> this might be broken in some situations.
> Also, are you sure you are using the same version of OGR for Mapserver
> as in ogrinfo? Seamless mapinfo support is *relatively* new so if your
> mapserver were built with an ancient version of OGR that might be
> the issue, though I think this is unlikely.
> Daniel Morissette is the authority on mapinfo support in OGR as the
> author of MITAB - the library used for it. If you have a very pressing
> need of assistance on this you could likely contracted him (via MapGears)
> for support.
> http://www.mapgears.com/
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
View this message in context: http://www.nabble.com/Mapinfo-Seamless-Vector-tables-in-mapserver-tf3349859.html#a9335655
Sent from the Mapserver - User mailing list archive at Nabble.com.
