Problems with zoomrectangle and MINSCALE with php mapscript
Alessandro Pasotti
ale.pas at TISCALI.IT
Thu Mar 15 14:41:25 EDT 2007
Il 17:07, martedì 6 marzo 2007, BJSVW PraktiantIn AGI ha scritto:
> Hi everybody,
> I have some problems with zoomrectangle and minscale. I`ve set the
> minscale in the WEB Object of my mapfile to 10.000
> Now I try to zoom in with zoomrectangle and this works fine untill a
> scale of 1:10.000. I'm using php mapscript 4.8.1
> But when I zoom to a scale bigger as 1:10.000 (eg 1:8000 it doesn't
> matter which scale) zoomrectangle gives me back an extent for my
> map with a scale around 1:14.000.
> Is this the result which zoomrectangle should deliver in this case?
Exactly the same happens to me with zoompoint.
There are two things you can try:
1 - set your minscale to MINSCALE - 1 ( 9999 in your case)
2 - check in your mapscript that you are not trying to zoom bigger than
minscale and change the zoom value to minscale if true.
For example (my minscale is 25000):
$new_scale = ($this->zoom_factor > 0) ? $this->old_geo_scale /
$this->zoom_factor : $this->old_geo_scale * ( - $this->zoom_factor);
if($new_scale < 25000){
return $this->map->zoomscale(25000 + 0.1, $xy_pix,
$this->mapwidth, $this->mapheight, $this->geoext0, $this->maxextent);
This code is in a wrapper class from p.mapper, but it sould be easy to
understand.
I see you have already opened a bug report, well done, I also feel this is a
bug.
Alessandro Pasotti
itOpen - "Open Solutions for the Net Age"
w3: www.itopen.it
Linux User# 167502
