Running MapServer from CD or DVD
Tim Bowden
tim.bowden at WESTNET.COM.AU
Fri Mar 30 00:14:03 EDT 2007
On Fri, 2007-03-30 at 15:26 +1200, Ian Tidy wrote:
> Hi All,
> Is it possible to run MapServer (and Apache) from a CD or DVD?
> Cheers Ian
In principle, I can't see why not. You're obviously running from a
windows system (or building a portable demo disk), otherwise under *nix
you'd just mount a hdd partition as read only. Google is good for
running Apache off a CD. There will be some need for writing to disk
though; Log files, tmp directory. And it will be slow from cd. Lots of
ram will probably help this a little. Can windows create and mount a
ram disk read only? That might be another option if you have gobs of
ram.
See
http://lists.maptools.org/pipermail/ms4w-users/2006-September/000631.html from the archives for a few hints.
HTH,
Tim Bowden
