Running MapServer from CD or DVD
Pericles S. Nacionales
naci0002 at UMN.EDU
Fri Mar 30 00:18:58 EDT 2007
Sure! You can use MapServer's map mode (mode=map) to generate your maps
without having to create a temporary directory. You won't be able to
use WMS (and WFS/WCS) as they require IMAGEPATH and IMAGEURL (which
needs to be writeable) but chances are you don't want to use those
anyway. You might also be able to use OpenLayers if you don't want to
create your own interface.
To make this work on any CD/Drive drive, make sure to omit the drive
letter when defining paths in Apache and MapServer. See MS4W to get an
idea of what I'm talking about.
Cheers!
-Perry
Ian Tidy wrote:
> Hi All,
> Is it possible to run MapServer (and Apache) from a CD or DVD?
> Cheers Ian
> ______________________
> * Ian Tidy *
> * GIS Administrator *
> Works Asset Department
> Napier City Council
> Hastings St, Private Bag 6010, Napier, New Zealand
> * Phone +64-6-835-7579 Ext. 8115 *
> Fax +64-6-834-4195
> mailto:iant at napier.govt.nz <mailto:iant at napier.govt.nz>
> http://www.napier.govt.nz <http://www.napier.govt.nz>
