Problem: ANGLEITEM and TRANSPARENT
Daniel Morissette
dmorissette at MAPGEARS.COM
Fri Mar 30 07:53:41 EDT 2007
I didn't follow the previous posts in this thread, but just in case I
thought I'd ask: did you try setting TRANSPARENCY ALPHA in your layer?
Daniel
Peter Sykora wrote:
>> As a follow up. The patch was not as complete as I hoped. I worked on the
>> problem until late last night but did not end up committing anything- still
>> working on it though.
> Hello Steve,
> what ist the current status concerning that problem?
> I´ve experienced the following problems (ms4w, mapserver 4.10.0) creating a
> road sign renderer where I want to align road signs along the street path:
> - As described in the previous posts the transparency does not work
> correctly when the symbols are rotated. My experience is that the resulting
> image is transparent, but overlapping symbols are excluding each other (see
> attachment and view roadsigns_rotated.png in a viewer that is able to
> display transparency)
> - The transparency works fine when the symbols are not rotated using png
> export, but when using jpeg output the transparency is gone.
> I really hope there is a solution for that ...
> Best regards
> Peter
Daniel Morissette
http://www.mapgears.com/
