issue with classitem and tileindex...
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Mar 30 09:47:01 EDT 2007
John,
Here is my layer setup and it works just fine. But I think you need to
go back to your ROOT error message.
>>> msDBFGetItemIndex(): DBASE file error. Item 'CFCC' not
For example what to you get if you run dbfdump or
ogrinfo -so landmark.dbf landmark
-Steve
# Area Landmarks
LAYER
NAME "Area_Landmarks"
STATUS DEFAULT
DATA "landmark"
TYPE POLYGON
TILEINDEX "tgrindex"
MAXSCALE 500100.0
LABELMAXSCALE 10100.0
CLASSITEM "CFCC"
LABELITEM "NAME"
CLASS
NAME "Military"
EXPRESSION /^D10/
COLOR 153 153 102
# Military Installation or Reservation
OUTLINECOLOR -1 -1 -1
LABEL
FONT "arial"
TYPE TRUETYPE
POSITION CC
SIZE 7
BUFFER 4
COLOR 0 0 0
OUTLINECOLOR 245 245 231
ANTIALIAS TRUE
PARTIALS FALSE
END
END
END
John Cole wrote:
> Brent,
> Well, I didn't know about the 'newer' method. I got it working similar to
> the 'old' one but it still doesn't recognize the 'CFCC' column when I add
> the class item.
> Thanks,
> John
> Brent Fraser wrote:
>> John,
>> You could try the newer (and more flexible?) "two-layer"
>> style of tileindex specification:
>> LAYER
>> NAME "lpy_idx_lyr"
>> TYPE TILEINDEX
>> DATA "lpy_idx"
>> END
>> LAYER
>> NAME "landmark_polys"
>> GROUP "bound"
>> TILEINDEX "lpy_idx_lyr" # this points to the above layer
>> METADATA
>> "wms_title" "landmark_polys"
>> "wms_group_title" "landmark"
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> STATUS ON
>> CLASSITEM "CFCC"
>> CLASS
>> EXPRESSION "D82"
>> NAME 'Cemetary'
>> MAXSCALE 250000
>> STYLE
>> COLOR 209 208 204
>> END
>> END
>> END
>> I haven't tested this, so it may not work. The trick is to
>> tell Mapserver the CLASS is to be applied to the files
>> pointed to by the tileindex, not the tile index itself (I'm
>> sure it doesn't have an attributed named "CFCC").
>> Steve Woodbridge may have some insight into this, since it's
>> tiled vectors; I've only done tiled raster....
>> Brent Fraser
>> GeoAnalytic Inc.
>> Calgary, Alberta
>> ----- Original Message -----
>> From: "John Cole" <john.cole at UAI.COM>
>> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
>> Sent: Thursday, March 29, 2007 2:04 PM
>> Subject: Re: [UMN_MAPSERVER-USERS] issue with classitem and
>> tileindex...
>>> Steve,
>>> Thanks for the quick reply, unfortunately I had already
>> tried that :-(
>> found.
>>> Is there anything else that could be wrong?
>>> Here is my layer:
>>> LAYER
>>> GROUP "bound"
>>> TILEINDEX "lpy_idx"
>>> METADATA
>>> END
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> STATUS ON
>>> CLASSITEM "CFCC"
>>> TYPE POLYGON
>>> CLASS
>>> EXPRESSION "D82"
>>> NAME 'Cemetary'
>>> MAXSCALE 250000
>>> STYLE
>>> COLOR 209 208 204
>>> END
>>> END
>>> END
>>> We are using the current version of MS4W.
>>> Thanks,
>>> John
>>> Stephen Woodbridge wrote:
>>>> John,
>>>> In shapefiles attribute are all upper case. try:
>>>> classitem 'CFCC'
>>>> -Steve W
>>>> John Cole wrote:
>>>>> I have a couple of county shapefiles where I've created
>> a tileindex using
>>>>> tile4ms. When I render these with MS, things work fine
>> until I set the
>>>>> classitem, and then it can't find the classitem column
>> on the shapefile
>>>>> (in
>>>>> this case 'cfcc').
>>>>> Is there something special you have to do to use a
>> class item or label
>>>>> item
>>>>> with a tileindex?
>>>>> Thanks,
>>>>> John
>>> View this message in context:
>> http://www.nabble.com/issue-with-classitem-and-tileindex...-tf3488200.html#a9741591
>>> Sent from the Mapserver - User mailing list archive at
>> Nabble.com.
