MapInfo Styleitem AUTO
Richard Greenwood
richard.greenwood at GMAIL.COM
Tue May 1 15:59:23 PDT 2007
On 5/1/07, Daniel Morissette <dmorissette at mapgears.com> wrote:
> Hi Richard,
> A few hints to try to isolate the source of the problem:
> 1- Make sure you don't have two copies of GDAL on your system that could
> be conflicting (i.e. remove any old copies and do a clean build)
I bet I have two copies of GDAL. I had 1.3 and then did a built &
installed of 1.4. Can you suggest the best way to remove GDAL?
> 2- Have you tried dumping the contents of the file using ogrinfo? If
> ogrinfo crashes then you know it's not a MapServer problem.
Yes, ogrinfo does work.
Thanks Daniel!
Richard Greenwood
richard.greenwood at gmail.com
www.greenwoodmap.com
More information about the MapServer-users
