MapInfo Styleitem AUTO
Daniel Morissette
dmorissette at MAPGEARS.COM
Tue May 1 16:33:02 EDT 2007
Hi Richard,
A few hints to try to isolate the source of the problem:
1- Make sure you don't have two copies of GDAL on your system that could
be conflicting (i.e. remove any old copies and do a clean build)
2- Have you tried dumping the contents of the file using ogrinfo? If
ogrinfo crashes then you know it's not a MapServer problem.
3- Also, if you just create a single static class for your layer instead
of using STYLEITEM AUTO then do you get a map or do you still get a 500
error?
Daniel
Richard Greenwood wrote:
> I did some upgrades over the weekend that have caused STYLEITEM AUTO
> to stop working on a Slackware 11.0 server. I upgraded
> postgres/postgis to the current versions and in the process decided to
> upgrade gdal from 1.3.2 to 1.4.1. I tested the upgrade on my
> development machine, a Mac w/ OS X, and it works fine.
> But on the Slackware machine I upgraded postgre/postgis and GDAL and
> rebuilt MapServer 4.10.0 and MapInfo layers with STYLEITEM AUTO fail
> to draw. Specifically, in the Apache log is a 500 error (server error)
> and nothing is written to the mapserver log file.
> I tried going back to GDAL 1.3.2 with a make, make install, and then
> rebuilding mapserver, but with same results. I also tried with
> mapserver 4.10.1.
> Any suggestions on where to look for the error, or how to get back to
> where I was before I did the upgrade?
> Thanks,
> Rich
Daniel Morissette
http://www.mapgears.com/
