POST request using CGI returns error
Jason M Sievers
j_siever at YAHOO.COM
Wed May 2 15:14:36 EDT 2007
Hey all. I am using version 4.9cvs(FWTools1.3.0) of the CGI MapServer. I
am able to send an HTTP GET request and get a map image from the MapServer
CGI just fine. However I am not able to get this to work using a POST
request. The error I get is 'loadMap(): Web application error. CGI
variable "map" is not set.' Code listings are below.
if (window.XMLHttpRequest) var oReq = new XMLHttpRequest();
else if (window.ActiveXObject) var oReq = new
ActiveXObject('Microsoft.XMLHTTP');
oReq.open('POST', '../mapserver/FWTools1.3.0/bin/mapserv.exe', true);
//oReq.open('GET',
'../mapserver/FWTools1.3.0/bin/mapserv.exe?mode=browse&map=bas.map&layers=all');
oReq.onreadystatechange = function()
if (oReq.readyState != 4) return;
if (oReq.staus == 200) alert(oReq.responseText);
else alert('A problem occurred while processing your request.');
oReq.send('mode=browse&map=bas.map&layers=all');
//oReq.send(null);
The lines I've commented out are for the GET request that works. Any
thoughts are greatly appreciated.
Thanks,
Jason Sievers
j_siever at yahoo.com
