non-tiff (24 bit?) raster layers in 4.10
Attila Csipa
plists at PROMETHEUS.ORG.YU
Mon May 7 11:30:42 EDT 2007
I'ma bit curious on the status of non-tiff raster layer handling in the 4.10
series of Mapserver. I'm a bit pressed for space on a server and tried some
alternative formats for the raster data and have interesting results compared
to what the docs on http://mapserver.gis.umn.edu/docs/howto/raster_data say.
For example, I tried converting to jp2 (with gdal_translate -of JPEG2000),
and while the GDAL log says everything's OK using these files, the rasters do
NOT appear (nor do they appear in GIF format, which I tried because it is not
a 24bit format). The raster only appears if the input is PNG or TIFF,
regardless of the output imagetype (jpeg, png, png24, etc). I'm using debian
etch packages on this specific machine. Any ideas or pointers on the current
state of affairs with non-tiff rasters ?
LAYER
NAME "TILE2"
STATUS ON
GROUP "Ortofoto"
DATA ortofoto/75795_48000.jp2
TYPE RASTER
END
debug log:
JPEG2000: IHDR box found. Dump: width=5000, height=5000, numcmpts=3, bpp=8
JPEG2000: Component 0: bpp=8, signedness=0
JPEG2000: Component 1: bpp=8, signedness=0
JPEG2000: Component 2: bpp=8, signedness=0
GDAL: GDALOpen(/data/ortofoto/75795_48000.jp2) succeeds as JPEG2000.
GDAL: GDALClose(/data/ortofoto/75795_48000.jp2)
GDAL: GDALDeregister_GTiff() called.
MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
GDAL 1.3.2.0, released 2006/05/02
The following format drivers are configured and support output:
VRT: Virtual Raster
GTiff: GeoTIFF
NITF: National Imagery Transmission Format
HFA: Erdas Imagine Images (.img)
ELAS: ELAS
AAIGrid: Arc/Info ASCII Grid
DTED: DTED Elevation Raster
PNG: Portable Network Graphics
JPEG: JPEG JFIF
MEM: In Memory Raster
GIF: Graphics Interchange Format (.gif)
FITS: Flexible Image Transport System
XPM: X11 PixMap Format
BMP: MS Windows Device Independent Bitmap
PCIDSK: PCIDSK Database File
PCRaster: PCRaster Raster File
ILWIS: ILWIS Raster Map
GMT: GMT NetCDF Grid Format
netCDF: Network Common Data Format
HDF4Image: HDF4 Dataset
PNM: Portable Pixmap Format (netpbm)
ENVI: ENVI .hdr Labelled
EHdr: ESRI .hdr Labelled
PAux: PCI .aux Labelled
MFF: Vexcel MFF Raster
MFF2: Vexcel MFF2 (HKV) Raster
BT: VTP .bt (Binary Terrain) 1.3 Format
IDA: Image Data and Analysis
JPEG2000: JPEG-2000 part 1 (ISO/IEC 15444-1)
FIT: FIT Image
RMF: Raster Matrix Format
RST: Idrisi Raster A.1
USGSDEM: USGS Optional ASCII DEM (and CDED)
