vector symbol origin not collocatedat POINT?
Charlton Purvis
cplist at SECONDCREEK.ORG
Tue May 8 17:33:00 EDT 2007
> Charlton, can you post a "existing" vs "desired" image? Plus the layer
> def... I don't think
> this is possible without hacking the code. Sounds like you want a POSITION
> control similar
> to what you have in a label object. Does that sound right?
Here is an example w/ all goodies attached.
I think you're right, Steve, the POSITION sounds like it would work. But
you'd still need to pick what part of the symbol will serve as the anchor --
so I guess that would always be the 1st point? That would work for me.
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070508/9ce70015/symbols.obj
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070508/9ce70015/g.gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070508/9ce70015/m.obj
