vector symbol origin not collocatedat POINT?
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Tue May 8 18:40:36 EDT 2007
By picking a position you'd move the whole symbol relative to the anchor point. Wouldn't matter if
it is first or last.
Steve
>>> On 5/8/2007 at 4:33 PM, in message <017d01c791b8$744557e0$650fa8c0 at latitude>,
"Charlton Purvis" <cplist at secondcreek.org> wrote:
>> Charlton, can you post a "existing" vs "desired" image? Plus the layer
>> def... I don't think
>> this is possible without hacking the code. Sounds like you want a POSITION
>> control similar
>> to what you have in a label object. Does that sound right?
> Here is an example w/ all goodies attached.
> I think you're right, Steve, the POSITION sounds like it would work. But
> you'd still need to pick what part of the symbol will serve as the anchor --
> so I guess that would always be the 1st point? That would work for me.
