Accessing images using time dimension.
Daryl Herzmann
akrherz at IASTATE.EDU
Mon May 14 10:16:22 EDT 2007
On Mon, 14 May 2007, Dave Weaver wrote:
> 1) What am I doing wrong (or not doing at all) ?
Can the web user that is connecting to the database see your tile table?
May need to grant select to that user?
> 2) Am I right in thinking the geometry column can be null and the rows
> will still be considered, depending on image_time ?
I don't think so, but am not sure. I insert the actual extent geometry as
well for my working config here. Can you try that once and see if that
works for you?
daryl
