Accessing images using time dimension.
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Tue May 15 08:09:51 EDT 2007
Dave Weaver wrote:
> (Apologies if this is a duplicate - I posted on Friday but haven't seen the
> message appear on the list, so I'm trying once again...)
> I'm having some difficulty displaying images using the WMS TIME=
> parameter to select different time periods. I've scoured the
> documentation, and although I get the general idea I don't see any
> document that explains the basic steps needed to get this working (the
> "WMS Time Support" document gives a rough idea, but misses out on some
> of the details), so I suspect I've missed something or got something
> wrong, but I've no idea what!
> This is what I've done:
> * I have done the following in Postgis:
> create table satellite (image_path text, image_time timestamp);
> select AddGeometryColumn('satellite', 'the_geom', 4326, 'POLYGON', 2);
> insert into satellite (image_path, image_time, the_geom) values,
> '/home/map/fgs/www/htdocs/maps/images/sat1.tiff', '2007-05-11 10:00Z',
> null);
> ('/home/map/fgs/www/htdocs/maps/images/sat2.tiff', '2007-05-11
> 11:00Z', null);
> * My .map file has (amongst others) these layers:
> LAYER
> NAME "time_idx"
> TYPE POLYGON
> STATUS ON
> CONNECTIONTYPE POSTGIS
> CONNECTION "dbname=map host=localhost"
> DATA "the_geom from satellite using unique oid using srid = 4326"
> METADATA
> "wms_title" "time index"
> "wms_srs" "EPSG:4326"
> "wms_timeextent" "2007-01-01/2007-12-31"
> "wms_timeitem" "image_time" #a column in postgis table of
> type timestamp
> "wms_timedefault" "2007-05-11T10:00:00Z"
> END
> END
> LAYER
> NAME "sat"
> METADATA
> "wms_title" "Satellite"
> type timestamp
> END
> STATUS ON
> TYPE RASTER
> PROJECTION
> "init=epsg:4326"
> END
> TILEINDEX "time_idx" # Layer name containing time index
> TILEITEM "image_path" # DB column containing path to image
> END
> * The URL I'm using to access the data is:
> http://localhost:8080/cgi-bin/mapserv?map=/home/map/fgs/www/htdocs/maps/postgis2.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=world,sat,radar&WIDTH=800&HEIGHT=400&FORMAT=image/png&TRANSPARENT=false&&BBOX=-90,-25,90,85&TIME=2007-05-11T11:00
> When I use this URL in my browser I see the underlying vector map
> layer, but no satellite image appears.
> So...
> 1) What am I doing wrong (or not doing at all) ?
Do you have your imagery displaying when doing a simple draw map ?
(either a wms getmap or mapserver cgi). This is to make sure that the
tile index and the pg layers are set properly.
> 2) Am I right in thinking the geometry column can be null and the rows
> will still be considered, depending on image_time ?
I think the geometry needs to be valid, each row of geometry should
normally represent the bbox of the image.
> 3) Is the duplication of the metadata in the 2 layers above necessary?
> I've done it this way because that's what's in the example in the "WMS
> Time Support" document, but do I really need to repeat all this
> information?
The matadata should only be necessary on the tileindex layer.
> 4) How can I debug this - is there some way I can find out *why* it's
> not displaying the raster layer? Is there maybe some way to show which
> time periods it's considering?
the wms time in your case ends up setting the filter element on your
postgis layer to something like :
"(date_trunc('minute',image_time) = '2007-05-11T11:00:00')" .
Assuming that your imagery is displayed without a time request,you can
manually set the filter element and see if that is working.
> 5) Is there some basic HowTo document that explains what I'm trying to
> do? (I couldn't find one).
> Thanks a lot
> Dave.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
