WG: OGR, ODBC join on OGR, ODBC
Arnd Wippermann
arndw at WTAL.DE
Mon May 14 15:52:36 EDT 2007
Hello,
I have an Access DB to hold the geometry as WKT-String and attributes of a
line layer and use OGR with ODBC to display my features.
GEOLINES the line geometry as WKT-String
GEOLINES_TREPPE the attributes for the lines
GEOMETRY_COLUMNS the configuration of table, objecttyp and srs
I have no problem with
CONNECTIONTYPE OGR
CONNECTION 'ODBC:GEOOBJEKT,GEOLINES'
to display my lines on the map.
But I want to classify my lines with values from the table GEOLINES_TREPPE.
In Access the following query delivers what I expect:
SELECT * FROM GEOLINES LEFT JOIN GEOLINES_TREPPE ON GEOLINES.ID_GEOOBJEKT =
GEOLINES_TREPPE.ID_GEOOBJEKT;
When I use this query for my GEOLINES layer in a mapfile and add the
DATA-line, nothing will display and also no error message is given.
With ogrinfo I get some output, but nothing with a clue to my problem.
ogrinfo" "ODBC:GEOOBJEKT"
ogrinfo" "ODBC:GEOOBJEKT" -sql "SELECT * FROM GEOLINES;"
ogrinfo" "ODBC:GEOOBJEKT" -sql "SELECT * FROM GEOLINES LEFT JOIN
GEOLINES_Treppe ON GEOLINES.ID_GEOOBJEKT = GEOLINES_Treppe.ID_GEOOBJEKT;"
I hope someone have an idea what to do. I want to use ODBC, because with a
little code I'm able to modify the tables from my map-interface.
#### Part of the mapfile ####
LAYER
NAME 'LINES'
GROUP 'LINES'
TYPE LINE
STATUS ON
CONNECTIONTYPE OGR
#without the DATA-line the layer will drawn
DATA "SELECT * FROM GEOLINES LEFT JOIN GEOLINES_TREPPE ON
GEOLINES.ID_GEOOBJEKT = GEOLINES_TREPPE.ID_GEOOBJEKT;"
DEBUG ON
CLASSITEM 'KATEGORIE' #column only in GEOLINES
CLASS
NAME 'Treppen'
EXPRESSION /TREPPE/ # with /./ is no difference
STYLE
COLOR 64 64 64
WIDTH 5
END
STYLE
COLOR 255 128 0
WIDTH 3
END
END
CLASS
NAME 'SONST'
STYLE
COLOR 0 255 255
WIDTH 2
END
END
Mit freundlichen Grüssen
Arnd Wippermann
http://gis.ibbeck.de/ginfo/
