AW: [UMN_MAPSERVER-USERS] Mapserver handling BBox in
different coordinate systems
Bart van den Eijnden (OSGIS)
bartvde at OSGIS.NL
Wed May 16 10:54:32 EDT 2007
Hi Milo,
this works fine for me:
http://webservice.nieuwekaart.nl/cgi-bin/nkn?request=getmap&version=1.1.0&SRS=EPSG:4326&Layers=nk_water,nk_groen,nk_landbouw,nk_recreatie,nk_voorziening,nk_gemengd,nk_wonen,nk_verkeer,nk_lijn,nk_plan&bbox=2,50,8,58&width=500&height=500
Note:
-epsg should be uppercase EPSG in a WMS request
-you are missing a lot of mandatory WMS GetMap request parameters, please
see the WMS spec for the parameters that are mandatory (Mapserver does not
check for this and uses defaults from the MAP file), btw I am even missing a
few in my example request.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Milo van der Linden <mlinden at ZEELANDNET.NL>
Naar: MAPSERVER-USERS at LISTS.UMN.EDU <MAPSERVER-USERS at LISTS.UMN.EDU>
Onderwerp: Re: [UMN_MAPSERVER-USERS] AW: [UMN_MAPSERVER-USERS] Mapserver
handling BBox in different coordinate systems
Datum: 15/05/07 23:21
> Hello Arnd,
> the @ is an error, my excuses. It indeed needs to be a & sign.
> The reason you get a white background seems to be that the standard
> bbox for EPSG:4326 is either undefined, or invalid. That is what I am
> trying to find out.
> Arnd Wippermann schreef:
> Hello Milo,
> botk links delivers the same map
> image. When I change the @ in the link, only for EPSG:28992 I get the
> map image. For EPSG:4326 I get only the credits and a white background.
> What's the meaning of the @ in
> the links?
