SIZE in percentages?
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Thu May 17 15:31:20 EDT 2007
Yes, the symbol scale is a reference scale. Scale (denominator) was chosen
to link size to because that was something GIS folks would relate to. Output
resolution and scale computations are joined at the hip. Change resolution
and you affect scale and hence sizes. That's not as direct as your idea but
then again folks don't change resolution much, as opposed to scale changes
from zooming in/out.
Applying resolution changes to MIN/MAXSIZE or MIN/MAXWIDTH values might
make some sense though. Those values are currently unaffected.
Steve
>>> On 5/16/2007 at 9:31 PM, in message
<4997F456680DAD4DA1E042C40C463611C34298 at auper1ex002.au.aecomnet.com>, "Delfos,
Jacob" <Jacob.Delfos at maunsell.com> wrote:
> Steve,
> Is a symbol scale like a "reference scale"?
> Ideally, objects shouldn't really change in size as a result of DPI
> setting, but I guess that's hard to change, since everything is defined
> in pixels (rather than points, or another absolute size)
> Would it be feasible to have a global "reference dpi" value, that
> resulting sizes are scaled to? For example, if a label is defined as 10
> pixels at a reference dpi of 100dpi, then it should come out as 30
> pixels if the dpi setting is changed to 300dpi.
> I'm asking because I have a print tool that allows setting of dpi values
> as well. I'd like the map to remain the same, regardless of dpi.
> Regards,
> Jacob
>> -----Original Message-----
>> From: UMN MapServer Users List
>> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Steve Lime
>> Sent: 17 May 2007 03:13
>> To: MAPSERVER-USERS at LISTS.UMN.EDU
>> Subject: Re: [UMN_MAPSERVER-USERS] SIZE in percentages?
>> Using symbol scales and then tweaking the resolution
>> parameter is the built in way to do this.
>> Symbol scale set the scale at which a symbol or label is
>> exactly SIZE pixels tall. The resolution
>> parameter (map level) affects the way in which scales are
>> computed. The default is 72 pixels
>> per inch which works ok for monitors but is too low for
>> print, where value of 300 or higher might
>> work better.
>> Steve
>> >>> On 5/16/2007 at 1:49 PM, in message
>> <d9824c396b0ffd49c957786adb749aff at 83.87.144.191>, "Bart van
>> den Eijnden
>> (OSGIS)" <bartvde at OSGIS.NL> wrote:
>> > Hi list,
>> > we've got a problem with labels getting too small in a PDF
>> print (not using
>> > Mapserver's PDF output btw). The WMS image requested for
>> the PDF print is
>> > approximately 2000 x 1500 pixels, and then squeezed into an
>> A4 PDF to get an
>> > appropriate resolution for prints.
>> > But since labels are 9 pixels only (the same MAP file is
>> also used for a
>> > webmapping application with a 600 x 400 map), they end up
>> being too small.
>> > Is there an option to have something like SIZEUNITS
>> percentage, and then use
>> > for instance a percentage of the image height for labels?
>> > Other options currently available already?
>> > Thoughts on this issue/enhancement appreciated.
>> > Best regards,
>> > Bart
>> > Bart van den Eijnden
>> > OSGIS, Open Source GIS
>> > http://www.osgis.nl
> This email and any attachments are intended solely for the named recipient
> and are confidential. The copying or distribution of them or any information
> they contain by anyone other than the named recipient is prohibited. If you
> have received this document in error, please notify the sender and delete all
> copies from your computer system and destroy all hard copies. It is the
> recipient's responsibility to check this email and any attachments to this
> email for viruses before use.
