WFS: Problems with multipolygons
Teemu Makela
teemu.makela at ARBONAUT.COM
Tue May 22 04:32:44 EDT 2007
Version of the MapServr is 4.10.1.
Where I could find version 4.10.3 or is it the SVN version. Current version
seems to be 4.10.2 (http://mapserver.gis.umn.edu/download/current).
Teemu
On Mon, 21 May 2007 13:31:31 -0500, Steve Lime <Steve.Lime at DNR.STATE.MN.US>
wrote:
>What version of MapServer are we talking about here? There were some
problems with
>certain multi-part features in older version of MapServer (I don't recall
exact version numbers
>but can check). I believe Bart identified a test case that the fix was
based on. The problem
>was in the GML encoder. 4.10.3 should be fine.
>Steve
>>>> On 5/20/2007 at 10:15 PM, in message <46510EBC.9030808 at univali.br>,
Fernando
>Simon <fsimon at UNIVALI.BR> wrote:
>> Hi Teemu,
>> Sorry for the delay to reply you message.
>> About this error, did you already tried to draw a map in CGI mode,
>> just to test all the polygons? Dis you already try to restrict the
>> objects in the data definition. Like: "GEOLOC FROM (SELECT ID_X, GEOLOC
>> TABLE_X WHERE ID_X = XXXXX) USING UNIQUE ID_X". Where the XXXXX is the
>> id for the object that are not draw?
>> About the objects, all have the same attributes, like SRID, GTYPE
>> and ETYPE?
>> I'm a not WFS specialist, I believe that the Bart can help in this
>> way, I can help with the Oracle relate issues.
>> Best regards.
>> Fernando Simon
>> UMN Mapserver and Oracle Spatial developer
>> Teemu Makela wrote:
>>> More information related to this issues.
>>> I tested the same layer through WMS and WFS. Layer works fine through WMS
>>> but WFS omits all execpt one part of the multipolygon. At below you will
>>> also find the mapfiles.
>>> See attached image "MapServer_WMS" which contains a multipolygon (5 parts
>>> with label 10404).
>>> See another attached image "MapServer_WFS_missing_polygons_labels_from_WMS".
>>> On this image only one piece of the multipolygon is visible. Labels are from
>>> WMS layer just to show that there should be more data (label is variable
>>> ID_X from mapfiles).
>>> Is it so that MapServer's WFS just cannot handle multipolygons or am I doing
>>> something wrong?
>>> ---- Mapfiles ----
>>> WMS layer drawing polygons:
>>> LAYER
>>> NAME XXXXXX
>>> TYPE POLYGON
>>> STATUS ON
>>> CONNECTIONTYPE oraclespatial
>>> CONNECTION "xxx/xxx at xxx.xxx.com"
>>> DATA "GEOLOC FROM TABLE_X USING UNIQUE ID_X"
>>> PROJECTION
>>> "init=epsg:2393"
>>> END
>>> CLASS
>>> NAME "GEOMETRIA"
>>> STYLE
>>> OUTLINECOLOR 200 200 200
>>> COLOR 255 0 0
>>> END
>>> END
>>> END
>>> WFS layer trying to draw polygons:
>>> LAYER
>>> NAME XXXXXX
>>> METADATA
>>> "wfs_title" "XXXXXXXX"
>>> "wfs_extent" "XXX XXX XXX XXX"
>>> "gml_featureid" "ID_X"
>>> "gml_include_items" "all"
>>> END
>>> TYPE POLYGON
>>> STATUS ON
>>> PROJECTION
>>> "init=epsg:2393"
>>> END
>>> DUMP TRUE
>>> CLASS
>>> NAME "GEOMETRIA"
>>> STYLE
>>> END
>>> END
>>> END
>>> Teemu
