Coordinates in degrees, minutes and seconds
H Garcia
helenagarcia at GRUPOTECOPY.ES
Fri May 25 05:40:35 PDT 2007
Hello!
I'm using a SQLServer database and an OGR connection, like this:
LAYER
NAME mylayer
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
"<OGRVRTDataSource>
<OGRVRTLayer name='mylayer'>
<SrcDataSource>ODBC:root/xxx at SQLServer</SrcDataSource>
<SrcLayer>pois</SrcLayer>
<FID>id</FID>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding='PointFromColumns' x='x' y='y'/>
</OGRVRTLayer>
</OGRVRTDataSource>"
PROJECTION
"init=epsg:4326"
END
TRANSPARENCY 50
DUMP TRUE
END
The problem is that the x and y table fields are strings so as "42ยบ 17' 30''N"
I would like to know if it is possible to make some type of transformation
between this representation and the decimal one, in order to mapserver to
understand my layer.
The database is not ours, and we access it through a stored procedure,
that's the reason why we can't make this simple operation in the origin.
Thanks in advance!
More information about the MapServer-users
