Coordinates in degrees, minutes and seconds
David Lowther
dlowther at COORDINATESOLUTIONS.COM
Fri May 25 08:56:01 EDT 2007
It might be easier to add a couple of fields to your database DDLat and
DDLong and calculate them via triggers from y and x. Then you could point
OGR at DDLong and DDLat...
David Lowther
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of H Garcia
Sent: Friday, May 25, 2007 8:41 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Coordinates in degrees, minutes and seconds
Hello!
I'm using a SQLServer database and an OGR connection, like this:
LAYER
NAME mylayer
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION
"<OGRVRTDataSource>
<OGRVRTLayer name='mylayer'>
<SrcDataSource>ODBC:root/xxx at SQLServer</SrcDataSource>
<SrcLayer>pois</SrcLayer>
<FID>id</FID>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding='PointFromColumns'
x='x' y='y'/>
</OGRVRTLayer>
</OGRVRTDataSource>"
PROJECTION
"init=epsg:4326"
END
TRANSPARENCY 50
DUMP TRUE
END
The problem is that the x and y table fields are strings so as "42º 17'
30''N"
I would like to know if it is possible to make some type of transformation
between this representation and the decimal one, in order to mapserver to
understand my layer.
The database is not ours, and we access it through a stored procedure,
that's the reason why we can't make this simple operation in the origin.
Thanks in advance!
