problems with Tiger road data
Dylan Beaudette
dylan.beaudette at GMAIL.COM
Fri May 25 16:01:58 EDT 2007
Hi everyone,
While I am quite familiar with some of the conventional problems with the
TIGER road data, I am a little confused as to why a specific county in Ca is
MUCH worse than other counties. Even adjacent counties have roads which are
generally closer to reality...
The general trend is an offset of about 100 - 300 meters to the north-east,
with the amount of distortion increasing to the east.
Here is a link to an example of offset local roads in Stanislaus county, CA:
http://casoilresource.lawr.ucdavis.edu/ka-map/htdocs/?map=casoil&cps=-2055233,-21524,12000
the offset from the imagery is quite obvious.
Does anyone know what might cause this county to be so much worse than the
others, and if there is some way I can fix the data? Right now it is stored
in a PostGIS table, so applying some kind of translation would not be that
difficult.
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
