WMS/WFS Authentication
Ed McNierney
ed at TOPOZONE.COM
Tue May 29 07:18:32 EDT 2007
Steve -
You're going to need to define your client requirements or you're going to continue to be buried in technology suggestions <g>!
There are plenty of options if you can dictate what the client does. There are very, very few options if you cannot. If you need to support unmodified ArcGIS 9.x desktop WMS clients, forget all the fancy technology because that client won't use it. If you are building the client yourself, you have a lot of tools available.
For better or worse, OGC seems to have decided that HTTP authentication and security were outside the scope of their HTTP-based specs. Unfortunately, some major clients have been implemented without any regard for that authentication!
- Ed
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Stephan Holl
Sent: Tuesday, May 29, 2007 2:45 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WMS/WFS Authentication
Hello Steve,
On Sat, 26 May 2007 11:00:36 -0400 Stephen Woodbridge
<woodbri at SWOODBRIDGE.COM> wrote:
> Hi all,
> What are people doing for WMS/WFS authentication when they set up a
> for fee service? Since this is not part of the protocol, I'm
> wondering how you might be doing this or if anyone is doing this.
To bring in some other words beside the already mentioned... You could
use deegree OWSProxy in combination with https to set up a secure
WMS/WFS-service. It has authentification based on WAS and WSS as well
as ordinary user/password-auth.
Beside that you could use InteProxy[2] on the clientside to make your
desktop client secure. Works well with QGIS, OpenJUMP and all JS-driven
webmap-clients like OpenLayers.
There is a demo at[3] to check out OWSProxy with InteProxy. Docs are
available here[4].
Best regards
Stephan
[1]
http://wald.intevation.org/plugins/scmsvn/viewcvs.php/docs/documentation/igeosecurity/deegree_owsproxy_documentation_de.pdf
[2] http://inteproxy.wald.intevation.org
[3]
https://inteproxy-demo.intevation.org/cgi-bin/frida-wms?version=1.1.1&request=GetCapabilities&Service=WMS
[4]
http://wald.intevation.org/frs/download.php/346/InteProxy-en-0.2.0.pdf
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
