Mapserver Color Binding: Blue and Green swapped (bug?)
Frank Warmerdam
warmerdam at POBOX.COM
Thu Nov 1 00:13:13 EDT 2007
Delfos, Jacob wrote:
> Hi List
> I am trying to make use of the colour binding feature, and it basically
> works, except... the colours are not quite right. My colours do not
> match those in MapInfo, although I can make MapInfo emulate the
> MapServer colours by swapping blue and green around. So basically: my
> RGB values are interpreted by MapServer as RBG.
> This happens for polygons as well as lines (haven't tried points). My
> data has been translated from MapInfo to PostGIS.
> I tried to lodge a bug in Trac, but it says "TICKET_CREATE privileges
> are required to perform this operation"
> Does anyone know more about this colour problem?
Jacob,
With some pointers from Howard, I found this segment of code in
bindColorAttribute() in maputil.c:
attribute->red = atoi(tokens[0]);
attribute->blue = atoi(tokens[1]);
attribute->green = atoi(tokens[2]);
I think this is responsible. If you are building from source, try just
changing it to the more obvious organization. I'd also suggest you
file a bug in Trac on the issue we will see if there is a subtle reason
for this, or it's just a typo.
To file bugs you need an OSGeo Userid. The pointer to get an osgeo
userid which you can use to login with is under the title "Important
Notice" on the http://trac.osgeo.org/mapserver page. The same userid
can be used for other OSGeo services like subversion, and other
trac instances (like GDAL's).
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
