Jørn Vegard Røsnes wrote: > I utilize proj4 to convert the lon/lat values to x/y for the > projection of the > image. These values I put into the tfw file. Hi Jørn, thank you for that hint, but I can't find how to use proj4 to covert these values. Would you mind giving me a quick example? Regards, Pascal
